96 civic temp gauge problem
Old 11-08-2010, 09:18 PM
TheMightySi's Avatar
Default 96 civic temp gauge problem
I have a 96 civic cx hatch that has had multiple engine swaps from b16,gsr,ls,type r and finally ls-t. The car has always had a problem with temp gauge not working correctly I have tried multiple clusters and needle broke on few. When i put the key on position 2 temp jumps up to middle and then when I turn on the car it goes up all the way to H as the cars warms up and stays there? My radiator fan dont come on by itself as well so I just jump it at the fan switch so its always on due to me never knowing the real temparature. I have traced temp wire yellow green from switch to cluster and seems to be good.
If anyone has any imput I surley would apriciate it. Thanks
Old 11-08-2010, 09:26 PM
Former User's Avatar
Default Re: 96 civic temp sensor problem
Use a multimeter to check for a short in this^ wire.
Old 11-08-2010, 09:29 PM
dpetro1's Avatar
Default Re: 96 civic temp gauge problem
there are three sensors when to comes to coolant temp. your fan problem and gauge cluster problem are probably not related.
1-wire sensor under the dizzy controls the needle on the cluster
2-wire sensor under the dizzy sends ECT to the ecu.
2-wire switch in the thermostat housing controls the rad fan.
test the gauge cluster wiring and sending unit like this:
then report back
Old 11-09-2010, 08:23 AM
I checked today with multimeter and there is no breakage in the wire I did test from cluster to the temp sensor wire.
Old 11-09-2010, 08:32 AM
resistance from PT to EG is 1.067
Old 11-09-2010, 10:04 AM
You need to check for a short not an open (broken wire).
Start by unplugging the 1-wire sending unit under the distributor. Does this make the cluster temp gauge needle stay at Cold?
Old 11-09-2010, 07:46 PM
If I unplug it, it just stays at middle if its on H it drops to middle when unpluged
Old 11-09-2010, 07:50 PM
If the wire running from the sending unit to the cluster does not have a short (continuity to body ground), then the cluster or temp gauge is bad.
Old 11-09-2010, 07:55 PM
So the 4 clusters I have changed were all bad? i had a dx ex si and now ctr cluster they all cant be bad. I mean the gauge goes back to 0 when car is shut off is spikes to middle when key is turned.
Old 11-09-2010, 07:58 PM
Unplug the cluster and the sending unit and measure resistance to body ground from either end of the wire using a multimeter. This will tell you whether there is a short, which seems likely based on what you have said.
Old 11-09-2010, 08:54 PM
I cut plug from spare harness spliced it to a new wire ran it to gauge cluster cut the cluster wire and same outcome, spikes to middle even with new wire ran to it. I left cluster wire cut, still spikes to middle with nothing connected to it.
Old 11-09-2010, 09:00 PM
The short must be in the cluster connector with sending unit wire. Carefully inspect that connector and the terminal for the sending unit wire for damage.
Old 11-09-2010, 09:04 PM
Another weird thing even with the cluster plug with Y/G wire unplugged still spikes lol but when the one on the left is unplugged it drops
Old 11-09-2010, 09:10 PM
This^ means it's a cluster or temp gauge problem. The Yel/Grn wire pins to connector B (B12) and power for all the gauges pins to connector C (C4). Unplugging connector C should make the temp gauge needle drop to Cold.
Old 11-09-2010, 09:17 PM
Ok you know what im having my friend bring his midori EK tomorrow I will put his cluster in and I can bet on same outcome, if so what you suggest from there?
Old 11-09-2010, 09:20 PM
If you unplug connector B and the temp needle still reads halfway, then the cluster or temp gauge MUST be the problem.
Old 11-09-2010, 09:26 PM
I will report back tomorrow
b18buck
11-02-2009 07:58 PM
klinster
09-23-2009 04:19 PM
klinster
01-17-2009 01:08 PM
PHILLIPDEEZ
06-02-2005 12:35 PM
Jaesung
07-01-2003 09:14 AM
Quick Reply: 96 civic temp gauge problem
