96 Civic Hatch Main Relay Problem?
Old 11-21-2004, 07:24 AM
Kevedge's Avatar
Default 96 Civic Hatch Main Relay Problem?
Everything is done, have the motor in, everyting hooked up, go to start it, and the fuel pump doesnt prime. From what Ive read its the main relay. I was trying to find some pictures on where it is located, but couldnt. Can you just replace the main relay? Also, when we put power the the yellow/grn wire on the fuel pump, its turned on, and we were able to start the car. But as soon as we took the wire off, it shut off. Any one have any info? Thanks in advance!!
Old 11-21-2004, 07:42 AM
paRRRker's Avatar
Default Re: 96 Civic Hatch Main Relay Problem? (Kevedge)
main relay is under the drive side dash to the left of the steering column usually right around where the under dash fuse box is...ive had two main relays go out on me...just pop one out...pop the other one in and your done
Jcgbeasttube
Honda Civic (2006 - 2015)
03-19-2018 10:07 PM
Just2Bar
05-19-2015 03:59 PM
98typerar
14
01-25-2014 03:34 PM
Slow96RedEk
07-27-2004 03:25 PM
wambus
02-12-2004 08:40 PM
Quick Reply: 96 Civic Hatch Main Relay Problem?
