96 Civic gauge needle lights and climate control lights don't work
Hey guys I need a little help troubleshooting an issue. It's a 96 Civic, I just bough it a couple weeks ago. So I noticed that the gauge lights don't work as well as my climate control buttons. Everything reads fine it's just the needles that don't light up. The numbers and check engine light brake light etc work. So I've looked and looked on here and other forums and I can't find a solution. I've checked all the fuses none of which are blown and it does have an aftermarket radio so I'm wanting to say it's something to do with that. I have replaced the dimmer switch it is NOT the dimmer switch and I have taken apart the underside of the dash so I can see all the wiring. No shorts or cut wires or anything. Anyone had this issue and have any ideas???Thanks so much in advance guys. David
Re: 96 Civic gauge needle lights and climate control lights don't work
have you thought that maybe the light bulbs are burnt out after 18 years? I know that happened with mine..
turbo_d
04-26-2015 10:01 AM
JMZ400
11-23-2014 07:42 PM
cebucivic
08-08-2010 09:07 PM
accord99power
06-16-2008 05:39 AM
92eg6
07-25-2004 10:03 AM
