96 civic dx
96 civic dx
I am having problems with my civic, it is not running properly. The car staggers upon acceleration and kind of sounds like it is fuel deprived. I changed out the fuel pump and filter and I also did the routine tune up things as well. I am at a stand still. I am about to take to the shop. I someone has question I can explain more.
Re: 96 civic dx
When you say "staggers", is the car bogging - as in stutters in and out of acceleration when you're heavy on the throttle or does the problem occur at any rate of acceleration?
Re: 96 civic dx
The check engine light was on, then I deleted the code and it has not come back on but the problem is still there. The bogging is intermittent, it works sometimes when I ease on the throttle, the other times I have to come to a complete stop and baby it with the gas, till she decides to go. But at an idle she purrs like a kitten.
Re: 96 civic dx
You might also want to just try replacing the spark plug wires and see if that fixes it.
Re: 96 civic dx
Misfiring at low rpm and heavy throttle is usually weak sparks. Starving for gas is usually more apparent at high rpm.
So like EJ699 said, I would start with new plugs and wires. Also check the distributor cap for cracks. You generally can't tell if wires are bad by looking, but if you see sparks on the outside of the wires when running the engine in the dark, they're definitely bad.
Re: 96 civic dx
New findings I was checking the throttle position sensor and I see that the housing is cracked. And letting air in also, one of the two screws that hold the tps to the housing are not even threading into nothing. Could that be the reason the car staggers and is hard to start.
GsrRussell
09-24-2008 08:32 AM
geneeunit
04-09-2008 09:49 PM
andrew n
11-30-2002 12:53 PM
