96-98 and 99-00 dash compatibility....
Are the two named dash pads the same? I know that they LOOK the same, but I hate to attempt a swap and have the newer one be a little different. I would be pretty angry. Can anyone tell me if they are the same?
Re: 96-98 and 99-00 dash compatibility.... (4g4me)
Dash pads?
Are you talking about the climate control console area thingy mabob doodadily hotdoggity dip?
Yah, I don't think it plugs in right..
Re: 96-98 and 99-00 dash compatibility.... (b16matt)
If you are refferring to the center climate control system these are not compatible. The 96-98 climate controls are of the slide lever variety, where as the 99-00 are controllled by dials that use electronics to open and close vents, etc.
If you are reffering the the guage cluster then yes those are compatible.
Re: 96-98 and 99-00 dash compatibility.... (qcoffey)
I was refering to the dash pad alone. The a/c controls and everything else will be staying the same.
Re: 96-98 and 99-00 dash compatibility.... (Nameless)
when you remove a dashboard, the unit comes as a whole........then you can remove the vinyl covered pad .
I want to swap just the pad over to my 98 hatch, because mine has blemishes. The pad is just the part that you see when it is installed, the actual dash is a metal frame that the pad bolts onto.
sorry for the mass confusion, I didnt think pad would be that hard to figure out, since it is a vinyl covered <U>padded</U> plastic.
I don't think the pad can be replaced. I tried to pull the pad off of a 95 dash and there was no way to replace it. I ended up getting a new dash from the junk yard.
Uljima
11-22-2016 07:48 PM
import-tooner
04-05-2009 07:36 PM
ThE BiG RauL
10-29-2008 12:30 PM
STPREZ
03-15-2006 07:22 PM
DannyITR
11-12-2004 09:58 AM
