Are 96-00 LCAs interchangable?
I recently got in a accident involving a bowling ball sized rock. I was going 45 late Wednesdsay evening, glanced down at my cell, then looked up and saw something in the middle of the street, by the time i figured out what it was, I was too late to out manuever it.. it scrapped my lip and hit the outside of my rim putting a huge dent on it. Theres a huge hole in my side wall.. fucking sucks.. I bent my front driver side LCA.. here are the pics.. (yes I know my car is dirty, its been raining nonstop for 2 weeks here)
http://www.bri4n.com/rock05.jpg Poor lip.. http://www.bri4n.com/rock03.jpg Anyone selling one Si rim? https://honda-tech.com/forums/images/smilies/emsad.gif http://www.bri4n.com/rock07.jpg Here you can see the wheel pushed back just a little bit.. Are 96-00 Civic front LCAs interchangable? If they are, I'm gonna go to a junk yard later this week. I need to get these parts asap as this is my only form of transportation. I would also like to give a big FUCK U to the shitface that left that rock there.. https://honda-tech.com/forums/images...s/emthdown.gif |
Re: Are 96-00 LCAs interchangable? (motion)
I'm pretty sure they are interchangeable..sucks about that though.
Yep should be https://honda-tech.com/forums/images/smilies/emthup.gif Sorry bout the car bro
yes they are. I have 99 from ex lcas on my 96 dx hatch.
No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. The SI also has a different fork then the rest.
Re: Are 96-00 LCAs interchangable? (rukawa1one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. </TD></TR></TABLE>
I thought all Civics had the same front sway bar. |
Re: Are 96-00 LCAs interchangable? (dsmfan95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">No they are not! The 99-00 SI have a different sway bar mounting points than the 96-00 EX, and the 96-00 DX- which have NO sway bar mounting points. The SI also has a different fork then the rest.</TD></TR></TABLE>
he is absolutely correct https://honda-tech.com/forums/images/smilies/emthup.gif |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsmfan95 »</TD></TR><TR><TD CLASS="quote">
I thought all Civics had the same front sway bar.</TD></TR></TABLE> No they don't. I know the SI uses a 26mm sway bar with a ball joint type endlinks, EX and LX uses a slightly smaller one with ruber bushing type endlinks, but I'm not sure of the exact diameter. The way these bars mount onto the LCA is different. |
Yeah they are interchangeable if you have a CX/DX/LX/HX/EX but the Si ones are different for the sway bar mounts. Also I had a friend that had almost the same thing happen as you and it didn't bend the LCA because they are pretty strong, but it bent his front sub-frame instead. Just thought I should put this out there just to make sure that is what it is. Good luck that sucks that happen, I hate stuff laying in the road.
No they don't. I know the SI uses a 26mm sway bar with a ball joint type endlinks, EX and LX uses a slightly smaller one with ruber bushing type endlinks, but I'm not sure of the exact diameter. The way these bars mount onto the LCA is different.</TD></TR></TABLE> EX and LX uses the same 22mm sway bar, with the different endlinks. |
Re: Are 96-00 LCAs interchangable? (haccord2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haccord2.2 »</TD></TR><TR><TD CLASS="quote">Yeah they are interchangeable if you have a CX/DX/LX/HX/EX but the Si ones are different for the sway bar mounts. Also I had a friend that had almost the same thing happen as you and it didn't bend the LCA because they are pretty strong, but it bent his front sub-frame instead. Just thought I should put this out there just to make sure that is what it is. Good luck that sucks that happen, I hate stuff laying in the road.</TD></TR></TABLE>
Ya that's right, they are all interchangable because the chassis is the same from 96-00. But i'm just saying this to the original poster...If u have an SI, just get another SI LCA. U wont be happy if u get an EX LCA and find out it wont fit ur swaybar. |
Thanks for the replies. Does anyone know the part# for the driver side LCA?
