95 Si VSS same as DX or EX?
1 Post
Hey,
I'm wondering if the Vehicle Speed Sensor is the same on a 95 Si as the Ex or Dx models. Please any info is helpful, thanks.
Re: 95 Si VSS same as DX or EX? (verycleanhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by verycleanhatch »</TD></TR><TR><TD CLASS="quote">it is the same</TD></TR></TABLE>
x2
x2
Re: 95 Si VSS same as DX or EX? (Ahknodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ahknodd »</TD></TR><TR><TD CLASS="quote">so then the B16 VSS and the D series VSS are the same?</TD></TR></TABLE>
a 95 si doesnt have a b16. it has a 1.6 sohc vtec
1 Post
Re: 95 Si VSS same as DX or EX? (Pr0ject93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pr0ject93hb »</TD></TR><TR><TD CLASS="quote">
a 95 si doesnt have a b16. it has a 1.6 sohc vtec</TD></TR></TABLE>
yeah you're right, that's what I had thought. Thanks for the help guys.
later, davey
later, davey
cute little bastard
Are you sure?
I've seen Z6s with the same style VSS as my B16:
And I've seen some D15B8s with VSS's like this:
Or was it because it was automatic or something?
Are you sure?
The B Series gear on the end of the VSS is "taller". Its about 1/4" taller than the single cam VSS. I cant remember if I tired to just flat out put the single cam sensor into the b series tranny, but...
I had a broken b series VSS, and had an extra single cam one. If you take the cotter pin out of the gear, it comes apart into 2 pieces. You can take your single cam gear and mate it to the top section of the b series VSS.
at the jetties fishin'
Re: (EgSalad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgSalad »</TD></TR><TR><TD CLASS="quote">The B Series gear on the end of the VSS is "taller". Its about 1/4" taller than the single cam VSS. I cant remember if I tired to just flat out put the single cam sensor into the b series tranny, but...
I had a broken b series VSS, and had an extra single cam one. If you take the cotter pin out of the gear, it comes apart into 2 pieces. You can take your single cam gear and mate it to the top section of the b series VSS.</TD></TR></TABLE>
taht's probably only true for hydro bseries transmissions.
the gear on a b-series CABLE trans is exactly the same as that on a d-series manual trans.
even down to the color and teeth count.
I just had my 91 LS VSS sitting right next to the 94 ex VSS I'm using in my swap and they are identical.
I'm using it right now and the speedo works just fine.
96LSTegra
07-25-2004 07:15 AM
