95 coupe WONT REDLINE ???
Old 11-23-2008, 08:54 PM
daymkimchee's Avatar
Default 95 coupe WONT REDLINE ???
I have a 95 coupe ex stock motor with only 110k on it . Ever since i bought it the redline always cut at 6200 rpm i have tried switching out the ecu to another p28 and even tried a jdm p30 but the same result .Why wont my car rev up to 7200 rpm ??
Old 11-23-2008, 08:56 PM
z6hatchboy's Avatar
do you have a cel? Its probably a sensor problem...as always. you might try a search theres a lot of these kinds of problems floating around
Old 11-23-2008, 09:39 PM
thats the only thing i have no engine check light everthing works fine but thanks
Old 11-23-2008, 10:01 PM
slo_hatch's Avatar
yes a d16z6 should be able to rev to 7200 rpms...i would check to make sure all your sensors are good and your tune up is recent.
Old 11-24-2008, 04:07 PM
how can i check all the sensors if there is no check engine light showing any of them wat would u recomend start
Old 11-24-2008, 04:37 PM
robfrmny21's Avatar
why u want to rev that high its a single
Old 11-24-2008, 07:47 PM
slimjimming6688's Avatar
maby it has something to do with fuel
Old 11-24-2008, 08:57 PM
because its suposed to rev that high stock
Old 11-24-2008, 09:12 PM
95dxsir2's Avatar
it's a hell of a lot easier if you had a scan tool to read tps values.
Darrell Woods
38
09-20-2015 07:34 PM
takeachance13
07-07-2014 11:55 AM
MySelfAffliction
10-01-2012 01:35 PM
DJEvo1200
23
08-21-2010 11:01 AM
jry2598
03-04-2008 10:57 AM
Quick Reply: 95 coupe WONT REDLINE ???
