95 civic with LS won't idle once warm.
i just got a 1995 honda civic cx with and ls swap and it has a cel for the IAC i replace it and it is still not idling what it is doing is once the car gets warms it will die period.
not sure what the problem is but maybe some one has had this problem so if someone could help it would be nice.
Re: 95 civic with LS won't idle once warm. (crazyguy)
sounds like a vacuum problem....check lines/hoses as well as all electrical connectors. While the car is warming up, discconnect the iacv connector and see if theres a change...if there's not, there's a wiring issue somewhere.
Re: 95 civic with LS won't idle once warm. (denraweb)
the idle is bouncie while warming up but then once it is warm it dies. but will start right back.
and the vacuum problem wouldn't that kill it befor it is warm also if that was the problem?
Location: Somewhere in the United States, united states
Re: 95 civic with LS won't idle once warm. (Sil84)
i kinda had the same problem with my CX but had stock motor and i tried changing my Throttle Body and the throttle body i put on it didn't have a place for the map sensor and the idle would jump and then shut off when eng light came on.... my guess would be make sure your using the right ECU and that its programed right
Re: 95 civic with LS won't idle once warm. (97civic94gsxr)
First unplug the IACV and turn the base idle screw to keep it running.
Leave it running until it gets hot then adjust the screw till the base idle is about 750-850 rpm.
Shut down the car and hook the IACV back up.
At this point if the iacv is working the car should idle right.
RipSiTurboHatch
06-01-2006 12:01 PM
mikeunreal
10-27-2005 02:39 PM
