95 Civic/B18c1 swap -- injector and fuel pump question
Whats up guys,
I have a 1995 honda civic si with a 96 GSR b18c1 swap in it. After some testing i have found out that two injectors are bad.
Since i have to replace the injectors, i was wondering if i should replace them with 240cc injectors or should i go a bit higher up rating wise?. Keep in mind the motor will be staying stock.
Also, i was curious to know if i should upgrade the fuel pump ? because it is a b18c1 inside a 1995 civic,
Any help would be greatly appreciated.
Thanks
Thanks
The Grumpiest
Re: injector/fuel pump question
Replace like for like. Larger injectors will not give you any additional power and may cause performance decrease without a tuned ECU. This isn't a big block unrefined domestic.
Terrible One
06-03-2006 09:01 AM
