95 Civic/B18c1 swap -- injector and fuel pump question
Old 10-04-2011, 10:16 PM
italian_virus's Avatar
Icon2 95 Civic/B18c1 swap -- injector and fuel pump question
Whats up guys,
I have a 1995 honda civic si with a 96 GSR b18c1 swap in it. After some testing i have found out that two injectors are bad.
Since i have to replace the injectors, i was wondering if i should replace them with 240cc injectors or should i go a bit higher up rating wise?. Keep in mind the motor will be staying stock.
Also, i was curious to know if i should upgrade the fuel pump ? because it is a b18c1 inside a 1995 civic,
Any help would be greatly appreciated.
Thanks
Old 10-05-2011, 04:40 AM
The Grumpiest
grumblemarc's Avatar
Default Re: injector/fuel pump question
Replace like for like. Larger injectors will not give you any additional power and may cause performance decrease without a tuned ECU. This isn't a big block unrefined domestic.
Old 10-05-2011, 06:01 AM
so then i should stick with 240cc injectors and the stock fuel pump??
Old 10-05-2011, 06:07 AM
The Grumpiest
Default Re: 95 Civic/B18c1 swap -- injector and fuel pump question
Stick with the injectors for the engine. Whatever those are. Fuel pump should be fine.
Old 10-05-2011, 07:06 AM
dpetro1's Avatar
Fuel pump and injectors flow the same on civics and integras. So no upgrade needed.
umair
11-29-2007 11:49 AM
Terrible One
06-03-2006 09:01 AM
buckysi
03-06-2006 03:54 PM
mike3
10-02-2004 04:52 PM
Speedfreak
04-18-2003 12:27 PM
Quick Reply: 95 Civic/B18c1 swap -- injector and fuel pump question
