95 Civic/B16a3 swap - cranks but wont start
I have a 95 Honda civic with a B16a from a 1994 Del sol. I recently reserfaced the head, put ARP heard studs, new head gasket, new timing belt and water pump. also new valve cover gasket. For fome reason my car just basicly just died out. once I pulled over I went to start it and it would just crank and not turn over any sugestion?
re: 95 Civic/B16a3 swap - cranks but wont start
I have to guess that you did these changes and things were fine but then things went bad all of the sudden . Right??
Check All Fuses.
Check All Grounds.
Do you hear fuel pump prime when putting key to "on" position?
Check mechanical timing (maybe jumped a tooth)
Check All Fuses.
Check All Grounds.
DumpdEJ6
21
05-25-2011 11:31 AM
