94 Si differential bearing size?
D Tranny Guru
Re: 94 Si differential bearing size? (POS Hatchback)
Si/EX S20 trannys get the 40 mm bearings.
What is the casting code near the fill plug???
Yours should read P20/B000 if it is a 92-95 EX/Si tranny.
Re: 94 Si differential bearing size? (Mista Bone)
I have no idea what the casting code is, Ive been too lazy to get underneath the car and look. Is there any difference between a 92-95 ex/si tranny and a 96-00 ex tranny? I need to get either my tranny rebuilt or a newer one without grinds/worn synchros. Id also like to purchase a quaife differential and the ones for the 88-00 civics with the 40mm differential bearings are $695 as opposed to the ones with the 35mm bearings which are $895
