94 H22a 94 eg
94 H22a 94 eg
It starts up and idles between 800 and 1200 slowly...vacuum leak somewhere ...BUT there's gas coming out the tailpipe enough to leave a wet spot on the ground after about a min or so and smoke
Ive checked ohms and volts in both o2 sensor and my injectors is 11.5 normal?
Any suggestions are helpful thanks!
Re: 94 H22a 94 eg
they're just stock injectors i believe saturated? no resistor...and i just have a stock fpr and fp...i tested my map sensor and im getting readings that aren't correct gonna switch that out and test my tps hopefully that solves somethings! thanks oh yeah and LTCxD2B it is is backfiring and it cuts out if i give it gas
Re: 94 H22a 94 eg
they're not^i doubled checked earlier...does anyone know where i can buy a dealers manual or something with really good detail on wiring more then a Chilton/Haynes?
girl_driven
05-02-2016 10:22 AM
