Please help with a broken upper control arm mount
Today I was adjusting my suspension and noticed that the upper control arm bolt in the rear was snapped off inside of the nut attached to the frame. I tried to drill it out and use a easy out to take out the remaining part of the broken bolt. I then tapped to brake the bolt out and all the sudden the nut welded into the frame separated from the frame. I was thinking of putting a nut behind the area where the original is but I looked everywhere and there is no way to reach the back end of the fender. Heres a picture to help you out. Is there Any way to reach the back of the fender? thanks in advance for your help.
Uploaded with ImageShack.us
LutherX
08-21-2011 07:59 AM
Tong.Y
06-14-2010 12:33 AM
