94 EJ1- HELP! tail lights + reverse lights + cluster + corner lights dont turn on!!!!
94 honda civic coupe ex
Basically my brake light works but when i turn my headlights on they dont work at all! as well as my reverse lights, corners and clusters! i check fuses look good not sure im looking at the right ones tho anyone can point to the right ones? anyone else seem to had this issue !
Re: 94 EJ1- HELP! tail lights + reverse lights + cluster + corner lights dont turn on
If you replaced fuse 19 with a known good fuse, then check the combination switch on the steering column.
you wiring might not be getting a good connection somewhere, or your headlight switch is out. both happened to me.
go to the junkyard and pick up a new switch for 5 bucks.
Gunny765
03-07-2015 10:07 AM
