94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
So I have a 94 del sol with a b-16 and just did a compression test. It came up between 165 and 175 psi. The motor has 243 thousand miles. Is that good compression or what?
Re: 94 del sol with b-16
did you do your test with the throttle body wide open??
Originally Posted by Deetz
(Post 44038284)
It was just turning key nothin else
Originally Posted by acdelcosol
(Post 44038308)
numbers will change promise. :thumbup: |
Should it increase or decrease?
increase.
chances are you'll be good with it post numbers after you do that. |
Sounds good. I figured with the amount of miles on the motor it would be less then that but I was pretty shocked.
Re: 94 del sol/B16 with 165-175 psi cylinder compressions - Is this good?
The engine should be warm too.
What does holding the throttle WOT do? I know it cancels injectors (well on Fords, atleast).
Originally Posted by ManicMike
(Post 44046234)
The throttle angle directly affects the cylinder pressure when the intake valves close, so it'll affect your cranking pressure too.
The engine was warm I did the cylinder closest to the distributor first it was 175 second was 173 third was 168 and 4th was 165.
