94 civic VX/99 GSR swap - Hard start, ruff idle when warmed up and won't rev past 7k
Old 11-25-2012, 06:48 AM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default 94 civic VX/99 GSR swap - Hard start, ruff idle when warmed up and won't rev past 7k
I posted this in here because there seems to be a little more traffic here rather than Hybrid and my problems are just as likely to affect a d series as it is my GSR swap.
Well since it got cold, I am having issues with car not starting right away when motor is cold (has always fired up right away), ruff idle when it warms up (doesn't always happen, tends to happen more after a spirited drive). The other thing that is driving me crazy is the motor won't rev past 7k. Never has since swap!
Running stock OBD-1 P-72
I have no vacuum leaks- checked and rechecked
IACV- spotless, could eat off it it is so clean!
99 GSR so no FITV.
Sensor are all installed correctly
Tried to calibrate TPS but volt meter was reading 5v rather than .5 and did not change when opened TB all the way???
Thought tach was off but it is spot on
Vtec works- 4500 RPMs everytime
I bought a Walbro 255 thinking maybe my Stock VX pump isn't able to handle the higher RPM's ??? Waiting for that to get in.
I am getting frustrated because I don't know what to do next to try and resolve these problems!!!
Any insight that could help would be much appreciated!!!!
Old 11-25-2012, 06:54 AM
jbpnoman's Avatar
Default Re: Hard start, ruff idle when warmed up and won't rev past 7k
Is the CEL on? Does it work?
Old 11-25-2012, 07:02 AM
Former User's Avatar
Tell us how you made these^ voltage measurements.
Old 11-25-2012, 07:44 AM
Yes forgot that cel does work but isn't on.
Ron- I took a paper clip and stuck it into the yellow/blue wire and grounded at the battery with my volt meter set on DC. I don't know why it kept reading 5v. Obviously something isn't right with that but I was tired of working on it last night and called it quits. About to go out there in a few and work on it some more.
The gsr swap I have has 85k miles. I am leaning toward replacing spark plug wires and distributor but don't want to start throwing money at parts and it not be the issue.
I went ahead and bought a walbro since I will be upgrading anyways once problems are resolved and I go boost. Figured stock pump could be on the way out since original motor did have 300k miles.
Old 11-25-2012, 07:48 AM
jbpnoman's Avatar
Which wire on the TPS are you reading off of? You might be reading the wrong wire.
Also, have you checked your timing?
Old 11-25-2012, 07:50 AM
JP-Yellow/blue stripe
I was just thinking about that and I am about to go rent a timing gun since I have yet to purchase my own to eliminate that possibility.
Old 11-25-2012, 07:56 AM
What car?
You measured the TPS reference voltage, which should remain constant at 5V.
Measure voltage between the Red/Blk and Grn/Blk wires by backprobing the TPS connector.
Old 11-25-2012, 08:02 AM
It is a 94 civic VX with a 99 GSR swap
Old 11-25-2012, 08:08 AM
99 GSR engine wire harness?
What are the colors of the other two TPS wires?
Old 11-25-2012, 08:20 AM
yes OBD-2a gsr wiring harness
green/blk and red/blk
The red/blk gave me a .55v reading with TB closed but gave me a 4.46 at fully open TB????
Old 11-25-2012, 08:23 AM
This is probably okay, but you might want to adjust the closed throttle voltage to 0.5V.
Did you use the Grn/Blk wire for ground in the voltage test?
Old 11-25-2012, 08:25 AM
jbpnoman's Avatar
Close, but slightly out of spec.
Old 11-25-2012, 08:33 AM
Yes I did, it read .521v but was 4.46 v when I opened the TB to full throttle. I guess I need to make slots with a dremel in the head of the screws for the TPS in order to adjust.
I thought it was suppose to drop to .46 when TB is opened ???
Old 11-25-2012, 08:37 AM
Default Re: 94 civic VX/99 GSR swap - Hard start, ruff idle when warmed up and won't rev past
Do an ignition system tune up, replace the fuel filter, and go from there.
Old 11-25-2012, 08:43 AM
Could you elaborate on that? plugs, wires, rotor?
Thanks for the help
Old 11-25-2012, 09:01 AM
Ignition system tune up --> Plugs, wires, cap, rotor, ignition timing.
Old 11-25-2012, 10:04 AM
I hate bad info!
Ok, thought so. I have had coil on plug since 2000 so I got a little spoiled not having to worry about a distributor and wires.
Old 11-25-2012, 02:39 PM
Car runs much smoother at idle... after it finds it! When I am slowing down driving, clutch in and the motor drops to idle, it will rev +/- 300-400 rpms for a few seconds and drop down to idle. Still wont go past 7k.
I am wondering if the ICM could be the culprit??? I did go with part store parts for now. The cap and rotor did appear original with a lot wear so any thing was a improvement. I will upgrade to OEM Honda parts after Christmas. My Christmas list was long and expensive and included a AR-15, Nardi wheel, HKS BOV so I had to cheap out for the time being.
Idle is a hell of alot smoother and a lot less rattles in my car (hasport mounts). Had to do some family time so I still have to check timing.
Old 11-25-2012, 07:36 PM
Well they don't rent timing guns so I bought the only one they had. Timing was advanced to the red mark (18). I adjusted so that I was advanced about a 1/8" past the green mark (14). The idle drop down to a nice normal idle. The car is much quiter. Being gutted with only carpet seats and dash, every thing rattles with my hasport mounts. The motor def lost a lot of vibration which I like.
It isn't reving up and down but when I was pulling in my neighborhood, my rpms didn't drop past 1100 rpms until I came to a complete stop and it finally dropped down to 850-900.
Still not getting past 7000k and cant figure that out for the life of me!!!
Old 11-26-2012, 09:45 AM
Some one mentioned their vtec solenoid screen being clogged up and causing a similar problem not reving past a certain rpm. Thoughts ???
boostedjdmdc2
13
10-27-2021 06:48 PM
HondaLove517
11-26-2008 11:51 PM
Touge Tuning
04-26-2006 11:51 AM
one slow coupe
12-24-2005 04:49 PM
Quick Reply: 94 civic VX/99 GSR swap - Hard start, ruff idle when warmed up and won't rev past 7k
