94 civic si abs delete
I want to do an abs delete on my 94 civic si. Im not really sure what brake components I can reuse and which ones I have to get. If someone could help me out with a list of parts I will need, that would be great. Thanks.
Re: 94 civic si abs delete
The ABS system is really just wheel speed sensors, fluid pump and a brain....so I guess if you wanted a full on delete you need to swap out axles and speed sensors, remove the ABS pump and install brake lines, and remove the brain/controller. It very well may be part of the ECU though.
Or I guess just pull the fuse. Seems like a large cost and hassle to remove the entire system...If you are looking for weight savings I would look elsewhere. If you don't like the way the system responds I would just disable it...
