94 Civic- pump won't prime
94 Civic- pump won't prime help help help!
I have a 94 honda civic dx i swapped a 1992 del sol vtec motor but now it wont start... i replaced the mayne relay amd also the fuel pump and nothing. Im running a p28 ecu that came with the motor aswell. Anyone help!!!! Cars been sotti g for more then 3yrs and still nothing. Tex me if possible 832 716 1671 i will also pay some one 2 start it i live in the cypress are on hwy6 and fm 529 rd thank you all.
Fuel pump wont prime
Last edited by chuckG897; 11-18-2015 at 11:04 AM. Reason: fuel pump wont prime! ! ! !
1994 honda civic won't start fuel pump won't prime
Well wen i bought the engine the guy told me it was in a 92 del sol. And the engine is the d16 z6 model. Bone stock
re: 94 Civic- pump won't prime
It dosent crank woth the key i have to run a wire feom the starter to the positive of the baterry in order for me to crank it.
Their was 2 diffrent cels lastime i check with the p28 i got a cel 14 - i think is a vtec cel im not to sure and with a p06 ecu i got a 02 censor ... i checkt all the fuces and they were not blown out i check them with a test light... does the key have to be on the on postion if im checking it with the test light?? Thank you guys !
Im just tierd of spending money and not getting anywhere
I never narc'd on nobody!
Do yourself a favor, stop using a test light, and use a voltmeter set to test resistance. You should read zero ohms across the two test pins of any fuse, regardless of what position the key is in.
Check the two fuses RonJ mentioned the correct way, and then check the ground that RonJ already told you to check. The only reason you're spending money and not getting anywhere is because you have chosen to. Stop throwing parts at it, and start doing proper diagnostics.
Re: 94 Civic- pump won't prime
Will do 1st i gata go get me a voltmeter and i have to have a day off jm working 12's all weekend long and wont have a free day till monday afternoon guys. Thank you
Ok guys so i checkt my fueces today and found acouple blowen out 21 and also a3 if im not mistaken. I was still not able to crank it do to the crazy weather in Houston but for sure try tomorrow afternoon when i get off work. I founda a wire that dosent seem to plug in anything can this be my problem ?
Yellow - black<br/>Orange- black<br/>Green- white <br/>Gray all gray colored<br/>
gunrok
12-24-2015 03:34 PM
asletclark
16
09-05-2012 04:21 AM
94EG2B18
63
08-31-2009 08:14 PM
