93 hatch bogs and dies
Picked up the hatch yesterday it was originally a autocar they converted to 5 speed Iit has a d15b7. At first it would run but whenever I went pass quarter throttle it would bog until higher rpms. Changed the plugs fuel filter and cleaned the injectors and it still did it. I unplugged the tps sensor and found that it ran no different whenever I plugged it back up it cut off. Ive reset the ecu and whenever I crank it it runs for a second, makes a gasp noise like its sucking in massivr air and cuts off. Could the tps be the culprit or should I look elsewhere?
Re: 93 hatch bogs and dies
I was having similar issues recently. First make certain that you have a manual and not automatic ecu, second check distributor, third and most likely your tps needs to be recalibrated.
lowda
14
03-20-2014 08:51 AM
jrhcivak
14
07-24-2012 05:06 PM
