b18b1 swap help??
b18b1 swap help??
Hi h t im new to hear and was hopeing if someone can help me out? I just finished a 94 b18b1 swap in to a 95 civic ej everthing went great except for now that the engines idle is all over the place and shaking or vibrating the car really bad what could it be ? Anyone please help, making me fill dumb that i cant figure it out and im really stumped.
Re: b18b1 swap help??
Did you check the head light fluid? jk jk jk I personally would look for a vacuum leak. Are you running an after market computer or have you made any modifications to your ECU?
Ha ha lol ya all the fuses are good. theres also no vacuum leaks that i can tell . Im running the stock p75 ecu with a rywire harness for the tcm . I also have a p06 ecu that is modified and chiped but it runs the same no madder what ecu im useing
I had a 90 integra that I swapped a motor with a bad head gasket and some bad rings for the exact same and it had a very similar issue even though the it was the same motors and it turned out to be a vacuum leak to the intake that I would have never found if a buddy had not pointed it out. I would check it over and listen just to be safe otherwise I have no idea but good luck ether way.
No cel and ya thats y ended up getting rywire obd1 to obd1 converson harness for the ecu to plug into the tcu so i didn't have to wire thoes two things but still had to connect to trans and shifter but that was easy
Found out it was a sprk plug now idles a lot better but still have a nother problem if i give it gas really slowly it will run if stomp on it it will bog down and die0
It just the injector wire that look bad but all have good conection its because there not stock i guess i could make them look better though
Ya my cel works sometimes i think lol i finally got code 15 ignitor output problly fried when spark plug gap was tuching and still had a misfire the coil or that other part next to it was bad it wasent fireing spark yright i swaped the in sides wit a 1.6 dohc zc distributor a really straightend it out
Michael Riegel
01-12-2017 05:17 AM
