93 Del Sol D16Z6 Idle Control Screw Not Functional
Title says it all.
Cleaned IACV, FITV, and even before this I believe the idle control screw is not functioning.
Just trying to adjust idle so it runs smoother when fully warm. Currently idling around ~600RPM.
Re: 93 Del Sol D16Z6 Idle Control Screw Not Functional
So.....while playing around with this...I was still not noticing idle change...unplugging the IACV (which threw a code) and adjusting the idle screw, shutting off car, plugging plug back in...resetting ECU by pulling back up fuse...and restarting vehicle..
So I pulled off the air intake...blocked the hole inside the throttle body..and nothing happens.
Bad IACV?
No CEL and yes, it works.
Bad IACV?
