Look for ECU and ECU help
Old 01-16-2010, 08:10 PM
hondakid09's Avatar
Default Look for ECU and ECU help
I got a 95 ECU for a honda civic EX. My Engine is a 94. would that work to gether?
my engine is a D16z6
if need more info to tell me ask plz
Old 01-16-2010, 08:54 PM
Matt93eg's Avatar
Default Re: Look for ECU and ECU help
Yes. The P28 ECU will work for any D16Z6 which came on EX/Si between 92-95. If you have a 5-spd make sure the ECU is 5-spd and auto for auto. You can convert an Auto ECU to 5-spd but I can't remember how, I did it back in 2005 on a P28. If you run an Auto ECU on a Manual, you will throw a code for a Lock-up solenoid.
Old 01-16-2010, 08:58 PM
civic_r87111's Avatar
^ Correctly informed
Old 01-16-2010, 11:55 PM
thumper64's Avatar
yeah, it'll work perfectly. To convert from auto to 5speed you remove resistor RP 17 and RP 18 and put a jumper (piece of wire, leg off a resistor, etc) across 18.
Then you can remove on of the 5151 high side switches and use it for a VTEC conversion on other ECUs.
While you're in there you may as well chip it and solder in a header for data logging and everything. It all takes a steady hand, but it's not bad if you know what you're doing.
gabriel0830
22
03-21-2013 08:32 PM
slowesteg
02-26-2013 05:18 PM
akouznet
05-24-2009 06:50 PM
That Guy 32
07-06-2007 07:44 AM
EJay1
02-28-2006 06:33 PM
Quick Reply: Look for ECU and ECU help
