93 Civic DX - Engine seems to be flooding after short trips (when engine is warm)
I've noticed this happening recently after installing a new distributor. When the engine is cold, the car starts up immediately and idles beautifully. If I drive the car on a long trip (30 minutes or more) and shut the car off, then start it back up, it generally starts right up with no problems. If I make a couple of short trips (5-10 minutes) and shut the car off, when i try to restart it, I notice the engine acts like it's flooded. It will sometimes sputter and then die, or sometimes just crank. If i wait a few minutes and open the throttle wide, it'll usually start up, idle rough for a few seconds, billow a cloud of white smoke from the exhaust, and then resume idling nicely. I also notice that after one of these "flooding" episodes it will act like it wants to bog down when shifting to Reverse or any drive gear (it's automatic). I've got some ideas as to what could be the culprit, and heard people mention at least as many more. Fuel pressure regulator, fuel pump, leaky injector, main relay, etc. The fuel filter is also brand new. Where should I start troubleshooting? Any ideas?
Re: 93 Civic DX - Engine seems to be flooding after short trips (when engine is warm)
Leaky injectors are easy to figure out. Do a fuel pressure test, and see how long it holds pressure. It should hold it for a few hours. With a leaky injector, it won't.
Yea, I need to get to the autoparts store to borrow their fuel pressure test kit tomorrow and check my results against the tolerances in the service manual. So you're saying to test for leaky injectors you simply leave the gauge hooked up for a few hours and see if the needle drops? Is there a way to isolate which of the four injectors is the problem?
Any easy way? Short of removing the injectors and feeling which one is wet, not really.
You could also pull your plugs and inspect them for fouling.
Alright, if I find the gauge dropping slowly tomorrow during the fuel pressure test, i'll pull the injectors and see if i can find the leaky one. Seems easy enough, it's all right there on top of the engine. I've already pulled the plugs and checked them out, but they're all basically brand new (less than two weeks old), so they haven't really had any time to become fouled. Thank you, sir.
Not a problem.
I would still pull the plugs and see if one looks visibly different than the other. Brand new plugs actually make a possible plug diagnosis a lot easier. At least we know any fouling on any of the plugs isn't old.
Compression test the cylinders.
w/o fuel pressure regulator hose attached: 44 PSI (right where it should be)
with fuel pressure regulator hose attached: 35 PSI (also, perfect)
After reconnecting the pressure regulator hose the pressure rose back to 44 PSI (which is what it should do)
However, when I shut the car off and let the fuel pressure gauge sit for a while, I noticed the pressure decline at the following rate:
Immediately after shut off: 35 PSI
+15 minutes: 28 PSI
+30 minutes: 25 PSI
+45 minutes: 23 PSI
+60 minutes: 21 PSI
+75 minutes: 20 PSI
+90 minutes: 19 PSI
This leads me to think (from jbpnoman's replies) that there's some sort of injector leak on at least one cylinder. Not sure if it's an o-ring or an injector itself. I checked the vacuum hose that leads from the bottom-right of the intake manifold to the engine block and it seems okay. I still have a full set of injector o-rings leftover from the head gasket set, so I might try putting those in and see if that does the trick before i spend ~80 bucks in a new injector. If anybody has any other ideas, I'd love to hear them.
I would send your injectors off to a professional cleaner before I looked at replacing them. A lot of the time, they can be refurbished for a lot cheaper. Injector RX and Witch Hunter both do good work, from what I've heard.
Are you talking about the o rings between the injector and the fuel rail, or the gaskets between the injector and the intake manifold? The gasket wouldn't cause your pressure to drop, but the o ring would, especially if you accidentally clipped it while doing your head gasket.
The o-rings I'm talking about are the ones between the fuel rail and injector. I've got a set of four (plus one for the pressure regulator too, i think) just sitting in my garage left over from the head gasket set. I might install those just to see if they do any good. If not... well then, hey, at least my injectors have fresh o-rings. :D
Well, I replaced the injector and pressure regulator o-rings and and that didn't do the trick. I ended up getting stuck at the gas station and had to wait like 10 minutes before the car started again. The dealership said a bad fuel pump seal could be causing it to lose fuel pressure after shut-down. Could that also cause the intermittent engine flooding? The pump certainly primes just fine and supplies good pressure when it's running.
ayub7337
08-09-2014 04:49 PM
