92 EG Hatch - Questions about tire wear and battery/fuse box relocation
My tires are treading on the inside, but I have skunk2 camber kit on the front. Can this be adjusted to correct the problem? Or should I just take it to a tire shop such as ken towerys, firestone, etc?
Also i did a prelude 92-96 console swap into my eg, looks really good but i was wondering if anyone had the ashtray or cupholder on here? What is this called above the radio in the picture and where can i get one? I thought it was called DIN pocket slot or something like that but can't find anything on ebay.
Thanks guys.
Thinking about relocating the battery, and fusebox going with a purple engine bay and some purple slips? Any ideas?
Thanks guys.
Re: 92 EG Hatch - Questions about tire wear and battery/fuse box relocation
You need an alignment machine to do it correctly or you may throw off the alignment. That being said, something in the suspension may be worn. Inspect or have the suspension inspected before the alignment.
Console pieces: http://www.hondapartscheap.com/find-...ANEL%20GARNISH
No comment on the purple. It's one of my least favorite colors but, to each their own.
When I relocated my battery I went and got a $20 set of jumper cable that are the same gauge as the battery cables. Way cheaper than buying 40ft of 6 gauge @ $5/ft.
Ek Forever y0!
This forum is almost strictly reserved for tech questions. You're asking several things here, one of which should be in the market place, another of which should be in the appearance forum, and another that should be in the suspension forum.
For your tire problem, your toe could be off. When you lower a car the toe tends to go inward I believe it is. Toe will eat through tires. Camber kind of does too, but not as much as toe. Get an alignment. As far as where to go, do some research on local places. I like to go to small businesses that are reputable. I hate Les Schawb. I do like Discount Tire, however.
The right purple looks good IMO. I think a metallic kind of purple looks very clean. Just my opinion, however.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/honda-din-pocket-lid-2883742/
Found that on here, any other things i could use?
Still looking for where i can find this pocket,
Oh they will be able to. Let us know what they say about your alignment and get a read out of the specs and show us. Tell us what they say. We'll try to protect you from them saying "uhhh yeah you need an all around camber kit and toe adjusters and tie rods and wheel bearings and blah blah blah." So, let us know
The Grumpiest
Tony's Wheel Brake & Alignment, they are actually a nice shop and seem to know what they were talking about.
sure they didn't mean negative camber, did they know you had a camber kit ?
my hatch is about the same height as yours and I'm like -1.6 camber without a camber kit and the shop never had issues setting the toe to spec also if you raised the car 3-4 inches you would be higher than stock
Yeah well i might try and bring it somewhere else to get it looked at but yeah they knew it had a camber kit on it, and my bad yeah negative camber. I really dont see why mine would be that much off its been lowered on full k-sport coilovers before i got it, they look older and dont ride amazing but i dont know if this would affect the improper tire treading because i started showing wires on the inside of my last set of tires, while having 50% tread on outside of tires
91efbluehatch
12-29-2010 02:50 PM
