92 d16z6 eg hatch help!!!
So my 92 eg with a d16z6 swap is throwing blue or white smoke when I crack vtec and only in vtec does anyone know what it could be? No lose of power at all
Re: 92 d16z6 eg hatch help!!!
Also vtec on the Z6 is minimum 4800 RPM. I don't have vtec but that's about the range I start smoking and I have solid 200 compression on all 4 cylinders. So more than likely oil control rings for me. Smoke only at high RPM usually WOT even though I can get it at 3/4 throttle just not as severely.
You could have a similar issue. If you get good compression numbers and don't smoke on take off until 4800+ rpm or smoke on deceleration, then you can pretty much rule out valve seals typically and the usual diagnosis is weak/bad oil control rings.
Your mileage may vary.
