92 Civic won't start
Re: 92 Civic won't start (EG8R)
Additional info on no start problem--- on further investigation I discovered that it also has no spark. I sprayed some carb spray into the intake while cranking and it didn't fire up , so I checked for spark and there was none. I also checked for code and it didn't show any. All of the main fuses under the hood are also ok, I checked them with a test light, to make shure there was current on both sides
I tell doctors what to do
Re: 92 Civic won't start (autodoc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autodoc »</TD></TR><TR><TD CLASS="quote">I don't have another ecu to try , could it possibly be the ignition switch</TD></TR></TABLE>I don't know, especially if you say it cranks. I don't have wiring schematics for everything right now.
Re: (yessewey)
I tried another ecu and now I have fuel pressure and the injectors seem to be firing( the plugs are getting wet) , but I still don't have any spark. The check engine light ,now goes off after a few seconds with the key in the on position, and it doesn't flash any codes when I jump the connection. IS there any way to check the dist connections, it has one with 2 wires and the other has 7 wires.
Re: (autodoc)
There is voltage at the coil in the dist, and the ground is good. I replaced the ign coil and the control mpdule, and still have no spark. The rotor turn while cranking the engine. I also replaced the cap and rotor
theofficialrj
21
04-12-2015 07:48 PM
civiclxb16a
33
03-07-2005 08:29 PM
