92 Civic won't start
engine cranks but, no fuel pump or fuel injectors firing
Re: 92 Civic won't start (autodoc)
check the main relay and other fuses
Re: 92 Civic won't start (jimmy o.)
The relay and fuses were the first thing that I checked, they're all good
Do you hear the fuel pump priming?
How do you know the relay is good? Is there fuel pressure? |
Re: 92 Civic won't start (EG8R)
I tried a new relay, there is no power at the fuel pump and no pressure in the system
Additional info on no start problem--- on further investigation I discovered that it also has no spark. I sprayed some carb spray into the intake while cranking and it didn't fire up , so I checked for spark and there was none. I also checked for code and it didn't show any. All of the main fuses under the hood are also ok, I checked them with a test light, to make shure there was current on both sides https://honda-tech.com/forums/images...es/emdgust.gif
Do you have a good ecu you can swap in to see if it will start?
Re: 92 Civic won't start (ILcrxsi1)
I don't have another ecu to try , could it possibly be the ignition switch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autodoc »</TD></TR><TR><TD CLASS="quote">I don't have another ecu to try , could it possibly be the ignition switch</TD></TR></TABLE>I don't know, especially if you say it cranks. I don't have wiring schematics for everything right now.
yea i agree could be the ignition switch
i would also say to try another ecu and see what happens
Re: (yessewey)
I tried another ecu and now I have fuel pressure and the injectors seem to be firing( the plugs are getting wet) , but I still don't have any spark. The check engine light ,now goes off after a few seconds with the key in the on position, and it doesn't flash any codes when I jump the connection. IS there any way to check the dist connections, it has one with 2 wires and the other has 7 wires.
Re: (autodoc)
Re: (autodoc)
There is voltage at the coil in the dist, and the ground is good. I replaced the ign coil and the control mpdule, and still have no spark. The rotor turn while cranking the engine. I also replaced the cap and rotor https://honda-tech.com/forums/images...es/emdgust.gif
