92 civic wiring questions HELP ASAP!
I have a 92 civic lx auto trans. I purchased an alarm with remote start, i have everything hooked up except the remote start and I need to know a couple wire colors and locations. I need to know the color and location of the oil pressure sensor wire. Also, there is supposed to be a neutral safety wire, is this only used on maual transmissions so that the car wont start unless you are in neutral? or do i still have to hook this up on an auto. please let me know, thanks.
oh, and please dont refer to me wiring diagram sites unless you know for sure it has the oil pressure sensor wire on there, because everyone i have checked does not mention it. thanks.
HT Order of Merit
Re: 92 civic wiring questions HELP ASAP! (egcivic611)
What the hell would you need the oil pressure sensor wire for when installing an alarm and remote start...?
As far as the neutral saftey wire, this is usually hooked to a toggle switch someplace, so you can disable the remote starter function. If you want to bypass, just put it to ground.
For vehicle wiring info: http://www.designtech-intl.com
nevermind the oil sensor one connects to the tach wire. and like i said, those sites dont give the info for the neutral safety...i've already checked all of them. thanks though
tUnz_on
27
10-19-2011 03:35 PM
chocolatesk8er10
Audio / Security / Video
04-29-2009 10:23 PM
