92 civic gsr no start help
Old 10-05-2010, 02:53 PM
turbogrs's Avatar
Default 92 civic gsr no start help
ok so my car almost got stolen stop them before they could now ever since then car doesn't start when it turns over it sounds like there is no enough power to crak the motor any suggestions would be helpful like i said the motor turns oved please help
Old 10-05-2010, 03:33 PM
Former User's Avatar
Default Re: 92 civic gsr no start help
What damage possibly relevant to a no-start problem did the thieves do?
Old 10-05-2010, 05:37 PM
turbogrs's Avatar
well they cut the alarm under the hood so I'm thinking its thwarted wire harness they damaged not sure though
Old 10-05-2010, 05:41 PM
fv8s's Avatar
well that could be an issue and is most likely causing your car not to start. what type of an alarm system is it
Old 10-05-2010, 08:27 PM
turbogrs's Avatar
ok i removed the alarm when i tried to start the car it seems like the battery is low ready to give up
Old 10-05-2010, 11:03 PM
EKtheory's Avatar
could it be the alternator? my friend ran into the same problemish..
his car was having a hard time starting up as well and would die out if we did manage to start it up. dont know if it is but check the alternator wires to see if they got burned or cut?
Old 10-05-2010, 11:23 PM
ek9800's Avatar
What kind of alaram was it? Did it have a starter kill? Check/test all your fuses in the fuse box in th engine bay.
Old 10-06-2010, 12:18 AM
-__-'s Avatar
oh man this sounds horrible. wiring issues always makes me frustrated. especially with kill switches :/
good luck. 808 rep!
Old 10-06-2010, 06:07 AM
fv8s's Avatar
why would you give up because of a simple no start problem? do research and keep trying new things and you will eventually get it
Old 10-06-2010, 09:45 AM
turbogrs's Avatar
nah i not giving up only got the car for just irritated going go through all the wiring this morning hopefully this works thanks everyone if get more suggestions lmk
Old 10-07-2010, 06:05 PM
turbogrs's Avatar
ok so i got.the engine to turn dead battery haha but i ain't getting spark i got fuel all injectors have power got a new dizzy all fuses are good replaced main relay with a new one still no start help anyone thanks
Old 10-07-2010, 06:45 PM
-__-'s Avatar
so ur not getting spark? did u replace the distributor cap, rotor, plugs and wires too? also check all ur grounds and the wiring for the dizzy on the harness side.
Old 10-07-2010, 06:49 PM
turbogrs's Avatar
ok so i checked the ground by the vavle cover an the one by the trans were else is there a ground
realis9
09-14-2005 10:20 AM
eg u y
11
03-11-2005 01:58 AM
Tr0LL
03-06-2003 09:57 PM
Tr0LL
03-06-2003 09:57 PM
FOrSfEd
05-27-2002 09:26 AM
Quick Reply: 92 civic gsr no start help
