92 civic with full gsr everything?
ok so i bought a rear end crash gsr! so my question is would i be able to put every suspension/steering thing into the civic?
i already know that the disks fit. Will the front and rear lca fit idk if there longer or not... also i plan on putting the steering rack on as well with the tie rods and all! would it work?
Re: 92 civic with full gsr everything?
https://honda-tech.com/forums/suspension-brakes-54/eg-dc2-suspension-arms-lcas-knuckles-forks-hubs-100%25-identical-2615331/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/help-gsr-sway-bar-eg-2735723/
http://hondaswap.com/hybrid-eg-ek-dc...n-swap-521230/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/gsr-suspension-into-eg-coup%E9-2252559/
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/will-dc-after-market-suspension-fit-eg-3040087/
http://6thgearadvertising.com/civic-...edce3e4b798efa
http://www.hondaforums.com/topic/372...t-by-eg-hatch/
Yes you can. Only things really worth changing out suspension wise is the the sway bars from the teg. Unless the teg as upgraded coilovers the stock units are no better than the Civic's. The B18C1 motor ad trans of coarse. The rear disc brakes off the teg. Inside you can swap out the front and rear seats. OH and the front brakes off the teg may be larger than the Civic depending on what model you have.
It's a power steering rack, which has a better turn ratio (a little under 3 turns LTL). If you have PS, this would be a good upgrade. If you don't have PS, you'll need to do a manual to PS conversion. All 94-01 Integras have bigger front brakes than any EG Civic, so definitely use those.
Depending on the model of Civic you have, you may need the rear LCAs to install the sway bar.
fm
fm
i got the steering rack Assembly and the front brakes on... the wheels seem to stick out more. dont matter to me i guess.. yea i have power steering and it notice i can turn more sharp... i'm in the verge of taking the stock drum breaks off and putting the rear disks on.. but i need a few more parts for it to work because i snapped one of the studs that holds the hub on the frame so i have to drill it out and re tap... but anyways... thanks for all the help
clutchkickphoto
08-30-2011 10:02 AM
