Head Lights
Unceasing Measure
Re: Head Lights (gduprice)
Bake them at 400 degrees for ten minutes, pry them apart, remove amber reflectors and inserts, put back together, plop back in the oven for 5 minutes on 400 degrees.
Bam.
Bam.
do they come apart with one 10 minute session in the oven? the only experience i had with doing this was with prelude tail lights and it took several times in the oven and had to pry it open bit by bit and use pennies to keep the lights apart while it was back in the oven. just thought id add that in case they didnt come apart in 10 minutes and you thought you were doing something wrong.
Re: Head Lights (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Bake them at 400 degrees for ten minutes, pry them apart, remove amber reflectors and inserts, put back together, plop back in the oven for 5 minutes on 400 degrees.
Bam.</TD></TR></TABLE> sounds like you do it quite often!! lol, i always use a heat gun but your way works just as good and its that simple
Re: Head Lights (scratchy)
Thats really how u do it never knew that, it sounds crazy, You have to put the whole head lights in side the oven at 400degrees. Its not gonna mess it up or sumthen. Do i need to put the foil in the oven and then the head lights on top?thnk u rply
mario_pic
12-18-2007 04:14 PM
