92-95 civic exhaust question
Does anyone know if 2dr exhaust will fit on a 3 dr car? also does anyone know if you can pass inspection with a high flo cat?
Re: 92-95 civic exhaust question (lillthingz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillthingz »</TD></TR><TR><TD CLASS="quote">Does anyone know if 2dr exhaust will fit on a 3 dr car?</TD></TR></TABLE>
Well, to my knowledge I believe the 2dr and 4dr exhausts are interchangable, if I remember correctly, the 3dr has the rear section bent slightly different (because the 2dr/4dr the bumper goes out more, so the muffler sits back more or has a longer tip), and the hangers are off (I know on the rear section), as far as the b-pipe I think its very close, I haven't tried the b-pipe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lillthingz »</TD></TR><TR><TD CLASS="quote">also does anyone know if you can pass inspection with a high flo cat?</TD></TR></TABLE>
If its a visual inspection and its a oem-looking high-flow cat (not one of those ebay blingy test-pipes they pass off for cats), then ur good. If you did get the ebay test-pipe cat then I'd throw the stock cat back on. Also they might say something if the exhaust sounds funny because of the highflow cat.
hth, if I'm wrong then somebody correct me, thnx.
-l8r
-l8r
I see I thought that the 2 and 3 dr would fit up almost exactly. But i gues not. As for the cat i supposibly need to get a new one because i failed emissions bad i had too much Nox so i duno what to do? help someone...
Modified by lillthingz at 12:29 AM 7/24/2004
gsp ej1-em1
11
07-16-2006 07:59 AM
