92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
#176
Re: 92-00 Honda Engine Swap Wiring Guide VTEC AND NON VTEC
"""OBD2 engine into OBD2 vehicle using OBD2 ECU (NOTE: YOU CAN NOT MIX 96-98 OBD2A and 99-00 OBD2B ENGINE AND DASH HARNESSES WHEN SWAPPING ENGINES INTO 96-00 CIVICS AS THE ECU CONNECTORS ARE DIFFERENT SEE FIGURE 11
D16Y8 using P2P ECU
DX/LX/CX - D16Y7
Mostly plug and play. VTEC solenoid, VTEC pressure switch and knock sensor will need to be wired in (Figure 6 for OBD2A, Figure 7 for OBD2B). Also the idle air control valve will need to be wire from 3 wire to 2 wire (Figure 6 for OBD2A, Figure 7 for OBD2B). The secondary O2 sensor wiring will have to be lengthened by using an O2 adapter if you are using an EX style catalytic converter. The intake air temperature sensor will have to be relocated in the intake arm somewhere as the Y8 manifold doesn't have a place for it (see figure 8)."""
nice info, I think it says what I see except for the distributor plugs are different, and my ECU's from both 00 and 97 civics have all pins present - no empties.... help!!
Does this writeup suggest using the original body and engine harness with the vtech engine and ECU? If so won't it need a jumper harness? The wiring is not even similar!
i put a 97 civic ex a/t d16y8 engine and harness and ecu into a 00 civic lx a/t d16y7 body!!!
Do I use the EX parts in the LX body then rewire - or - scrap the vtech power and use the Lx harness/ECU - or - scrap the entire vtech top half and use the entire Lx setup except for the EX bottom half engine?!?
D16Y8 using P2P ECU
DX/LX/CX - D16Y7
#177
Hey guys, I need some help. I have a 1998 Honda Civic DX and I just got a 2000 civic Si swap. It came with engine harness and computer. I am missing the plug connector A that comes from the main engine harness. My DX does not have that plug. Also I don’t see the plug for the canister box on the engine bay. Any ideas of what to do? I saw that that plug is for the fuel pump relay but there are a lot more wires though? Can someone point me on the right direction please.
#179
Can anybody tell me which of these wires I need to connect for my H22A swap to start with it’s new manual transition as well as the ones for the reverse sensor and speed sensor th als in advance
#180
Can anyone tell me if a 98 spec JDM ITR motor will be plug and play into a eg6 ? or point me in the right direction . thanks in advance
#182
Please do not use this thread for your technical questions for your car. Please start your own thread with all your pertinent information. Thank you.
HondaPartsHero
Engine Management and Tuning
12-05-2020 04:19 PM
