90 b18 in 94 civic
90 b18 in 94 civic
i am getting a b18 off my friend for 300 bux, it just needs a tranny, it is out of a 90 integra, will it bolt up to my 94 civic with the d16, or will u have to relocate the brackets, and what else should i get from him besides the engine to do the swap????
Just use your obd1 harness on the ls, u need unsaturated injectorsa unless you want to run a resistor box. Also if you can find a drivers side mount braket you can use obd1 b series mounts. Also don't forget you will also need an obd1 computer, or you can chip your obd1 computer with uberdata and burn an ls map into your ecu. I did this swap and it wasnt that hard as long as you have the parts you need.
Re: 90 b18 in 94 civic (honda_racer1986)
it's illegal in cal for sure cause your putting a 90 engine into a 94 car, the engine have to be the same or newer than the car
Re: 90 b18 in 94 civic (EvilPhu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilPhu »</TD></TR><TR><TD CLASS="quote">it's illegal in cal for sure cause your putting a 90 engine into a 94 car, the engine have to be the same or newer than the car</TD></TR></TABLE>hes in ohio though.
stevieturbos
11-08-2009 07:35 PM
allmotrwagn
11-28-2006 09:03 PM
lol_on_v8s
14
08-13-2006 01:15 PM
