90-93 integra tein shocks work on eg
Re: 90-93 integra tein shocks work on eg (spoonspeed)
do you have the teins already? If not just go with some ITR ones and get the lower contol arms, that will bolt up And if you mean the basic coilover set I dontt think you should need to change the springs...
Re: 90-93 integra tein shocks work on eg (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">the rears will bolt right up.the fronts will require EF/DA forks.
chris</TD></TR></TABLE>
Correct. The DA Tein Basic coilovers are a smaller diameter so the EG/DC fork will not be able to clamp onto it. Also, there's no brake line brackets on the DA Tein Basic coilovers, so you have to hammer/pop off the stock ones from DA shocks and slide them onto the Teins. FYI, overall height of the DA fork and the EG/DC fork is the same... just the EG/DC forks are wider and allow for more room for the axle.
1 Post
Re: 90-93 integra tein shocks work on eg (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">
Correct. The DA Tein Basic coilovers are a smaller diameter so the EG/DC fork will not be able to clamp onto it. Also, there's no brake line brackets on the DA Tein Basic coilovers, so you have to hammer/pop off the stock ones from DA shocks and slide them onto the Teins. FYI, overall height of the DA fork and the EG/DC fork is the same... just the EG/DC forks are wider and allow for more room for the axle.</TD></TR></TABLE>
got one question for you-are the EF forks shorter than DA forks?a few of my friends put EF shock/forks combos on their EGs to get more travel.it's been so long since we did it i can't remember if the EF shocks are shorter than EG/DC shocks or if the EF forks are shorter.i was thinking that both DA and EF forks are the same,and are shorter than EG/DC forks?
THANKS
Chris
THANKS
Chris
well see this is what happend i put the rear shocks on the car and put in down all the whay and there is a huge gap in between the fender and tire so then i lowerd the ride higeth and it was not much differnt. so know what
anothersickhatch
Suspension & Brakes
12-21-2005 04:18 PM
