Tein RA
Old May 4, 2011 | 03:47 PM
CRX-RX's Avatar
Default Tein RA
http://img818.imageshack.us/img818/6202/coverxw.jpg
http://img593.imageshack.us/img593/3631/catqk.jpg
Used exclusively as track day suspension, and stored indoors otherwise (in my bedroom and on the shelf for several years now). Tein RA's made for DCR Integra and modified to fit EF. They were modified by removing ~15-17mm of material from the front shock collar and removing an equivalent from the bottom of the shock mount to allow for axle clearance. They require the use of EG/DA forks (included) and integra type R rear control arms (not included).
These shocks can easily be refitted for use on an EG/DC chassis, if required, by adding a spacer of 7-10mm on top of the shock fork, and threading out the bases of the front shocks an extra 5-7mm over recommended initial setting. The rear is simply spun all the way down, so you only need to set them back at the recommended height.
Asking $1200
More detailed and larger pics available.
Contact danscherf@ymail.com
Only if you actually want a response of course! :D
It may take me a couple days to get back to you, but I will.
Old May 4, 2011 | 04:02 PM
4NLINE UNLIMITED's Avatar
Default Re: Tein RA
Do you know what the Spring Rates are currently?
Old May 4, 2011 | 04:36 PM
AFTERZERO's Avatar
Default Re: Tein RA
^ I would like to know spring rate as well, also are the collars all functional?
Old May 9, 2011 | 04:49 PM
CRX-RX's Avatar
Default Re: Tein RA
Sorry for the delay, I've had some technical issues with the site that locked me out for a couple days.
For those too lazy to read or click on a link: The front's are 783 and the rears are 559 (12/10).
As far as the functionallity of the collars; Officially, I don't know.
These shocks are not fresh off the illinois winters salty roads driven around on some slammed rice mobile. I've had no need to make adjustments in several years that they have been sitting on the shelf, but the last time they were in use they worked fine, and I see no reason they shouldn't now. I cleaned the shocks for the photos with a damp sponge, and all that came off was dust, so that should give you a little insight into their condition.
Old May 19, 2011 | 10:36 AM
CRX-RX's Avatar
Default Re: Tein RA
sUp
Old May 31, 2011 | 10:06 AM
CRX-RX's Avatar
Default Re: Tein RA
Bump
Old Nov 16, 2011 | 01:48 PM
CRX-RX's Avatar
Default Re: Tein RA
Perfect stocking stuffers! :D
Old Nov 16, 2011 | 08:58 PM
MikeySpec's Avatar
Default Re: Tein RA
http://www.youtube.com/watch?v=9x-6qtunUtw
Much Gracias to Dan for helping out on the project.
Buy these coilovers...they are no joke!
lonefuzzy79
Nov 19, 2005 02:06 AM
BACKintheDA
Jul 30, 2004 11:18 AM
nitrousrush
Jul 17, 2004 09:50 AM
visionsOFmadness
Dec 23, 2003 08:17 PM
Prevail
Jul 7, 2002 03:26 AM
