5 Lug Conversion Question!!
1 Post
Re: 5 Lug Conversion Question!! (00ek9)
i *THINK* that you wont because you cant/arent switching to ITR LCA's on your car, just the trailing arm, front knuckle assembly. So your good my friend..
yeah in the front you will keep your setup, in the rear it depends on whether you wanna run the ITR rear lca which will give you a hole to run a swaybar. If you chose to run that then you will need to change rear shocks otherwise you can keep your current setup with your stock rear lca
Re: 5 Lug Conversion Question!! (jonas)
you use your stock ones for 96+.
you can use your suspension.. i have it. believe me.
JDM honey
10-04-2007 08:59 AM
compwc18
04-09-2005 03:54 AM
1337 Si
19
11-17-2003 02:48 AM
