5-Lug Conversion
5-Lug Conversion
im looking to get a 5 lug conversion on my EG, i know i need the whole front hub, front LCA's, front sway bar, and hardware, the rear LCA's and sway bar, and the rear Hub
my question is is there any thing else i need to get this conversion, thanks in advance
also im fully aware about the ongoing debate about how getting the conversion is for show, but i really dont care, i'm getting them because i hate my rear drums and front brakes, which are oem.
Re: 5-Lug Conversion (Convoy)
as far as the front, knuckle along with rotor and caliper is the minimum you can get away with.
rear requires complete again hub/along with rotor caliper, ebrake cables and brake lines minimum - but personally I would try to get complete trailing arm as it has new bushing and is much cleaner.
conversion is no different then doing GSR/LS brake swap
http://tech.hybridgarage.com/tech/brakeswap.html
1 Post
basically you would want the complete front knuckle *dont need lca as you can use your stock ones.
Complete rear trailing arms with ebrake cables *again you can use your Lca unless you want to change to itr shocks as well.
Re: 5-Lug Conversion (eg6ajk)
[QUOTE=eg6ajk]
QUOTE]
Suppose that you already have a gsr upgrade, how much more would you need to go up to 5 lug?
Sorry to jack thread, but the thought of gunmetal itr wheels on my car puts a smile on my face.
QUOTE]
Re: 5-Lug Conversion (Dengar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">as far as the front, knuckle along with rotor and caliper is the minimum you can get away with.
rear requires complete again hub/along with rotor caliper, ebrake cables and brake lines minimum - </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dengar »</TD></TR><TR><TD CLASS="quote">[QUOTE=eg6ajk]
QUOTE]
Sorry to jack thread, but the thought of gunmetal itr wheels on my car puts a smile on my face.</TD></TR></TABLE>
then all u need is the knuckles.
QUOTE]
Munkyw3rkz.webs.com
1 Post
Remember you will be adding 45lbs tot he car and adding sprung weight!
https://honda-tech.com/zerothread?id=915556
i took my 5 lug off!!!!! went back to my old 4x114 ITR set up
Re: 5-Lug Conversion (SnoFlake EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnoFlake EG »</TD></TR><TR><TD CLASS="quote">Remember you will be adding 45lbs tot he car and adding sprung weight!
i took my 5 lug off!!!!! went back to my old 4x114 ITR set up</TD></TR></TABLE>
might be, but im getting a killer deal on it.
i'll just lose 45 pounds myself
http://tech.hybridgarage.com/tech/brakeswap.html</TD></TR></TABLE>
pshh, this is comin from an ex 5 lugger!
my ex clone!
my ex clone!
Munkyw3rkz.webs.com
1 Post
Re: 5-Lug Conversion (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
my ex clone!</TD></TR></TABLE>
actually im the X 5 luggin and your X clone!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloSilverEF »</TD></TR><TR><TD CLASS="quote">5 lug - Is it worth it? </TD></TR></TABLE>
it depends on how you look at it...the brakes are well worth it, but it will boil down too how you drive, what racing if any you do, and if you just want the JDM BLING.....
Modified by SnoFlake EG at 10:23 AM 7/13/2004
Re: (wdskuk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wdskuk »</TD></TR><TR><TD CLASS="quote">Hey Convoy. Who are you getting the 5 lug setup from.</TD></TR></TABLE>
i dont know yet, i found someone in WI selling it cheap
Re: (sloSilverEF)
YES YES IT IS !!!!!!
