2k ex motor into 93 eg???
hey wassup guyz imma bout to pick u pa 2000 ex sohc vtec complete swap tranny, motor, etcetc. was just wondering if it would swap into my 93 eg with no problems?? thanks
Re: 2k ex motor into 93 eg??? (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">hey wassup guyz imma bout to pick u pa 2000 ex sohc vtec complete swap tranny, motor, etcetc. was just wondering if it would swap into my 93 eg with no problems?? thanks </TD></TR></TABLE>
Re: 2k ex motor into 93 eg??? (USDM Tsuchiya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM Tsuchiya »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
whats with that?? i have a 93 dx.. i got a d15b vtec in it right now..but imma pick up a complete 2k ex motor from a friend..
Re: 2k ex motor into 93 eg??? (TorganFM)
i only put bout 2k in it... maybe less. its fine but it has a vacuum leak OR its the iacv valve. not sure.. im in cali pretty far from ya.. wouldnt know how to ship this motor.
Re: 2k ex motor into 93 eg??? (skunk2unerz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2unerz »</TD></TR><TR><TD CLASS="quote">yes it will fit... i have a 99EX in my 93 Cx HB. </TD></TR></TABLE>
kewl finally some help ? all ive been gettin are flames but one question did u have any problems with the install? thanks
its been awhile since i done it. If you use your stock wiring harness you will need to use your stock injectors. I went and used the 99injectors from the engine and rewired my stock hareness to the OBD2 injector clips. Since you already have a vtec harness you won't need to run a vtec wire. Should be a simple swap. Good luck
Everything thing else should be bolt on.
may i ask why you are swapping out the d15b? is it a mini-me, or the jdm type? if you swap the 2000 motor, you may have to do obdII - obdI conversion...
seems like too much work for .1 liter(s) of displacement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2unerz »</TD></TR><TR><TD CLASS="quote">its been awhile since i done it. If you use your stock wiring harness you will need to use your stock injectors. I went and used the 99injectors from the engine and rewired my stock hareness to the OBD2 injector clips. Since you already have a vtec harness you won't need to run a vtec wire. Should be a simple swap. Good luck
Everything thing else should be bolt on.</TD></TR></TABLE>
thanks.. but u sure i dont have to wire up vtec? my cars originally a 93 dx. i dont think they come pre-wired for vtec. am i wrong??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 »</TD></TR><TR><TD CLASS="quote">may i ask why you are swapping out the d15b? is it a mini-me, or the jdm type? if you swap the 2000 motor, you may have to do obdII - obdI conversion...
seems like too much work for .1 liter(s) of displacement</TD></TR></TABLE>
im gettin a whole complete 2000 ex swap for $400 thats y .. is that a good price? i got my jdm d15b for $350 just the motor. nothing else. i think imma be using my vtec obd1 wiring harness.. will that work?
oh i thought you had the JDM vtec engine. Well if you don't have vtec, then you will need to wire the harness for vtec--which isnt hard at all.
And yes you are getting a heck of a deal for a complete swap for $400. I bought mines for $500(motor only).
If you use the OBD1 vtec harness you will prolle have to take off the OBD2 injectors and use the obd1 injectors. If you dont go that route, then you will do like myself and use the injectors off the 2000 engine and convert your harness by using the clips from the 2000 wire harness. Fairly simple switch over.
im gettin a whole complete 2000 ex swap for $400 thats y .. is that a good price? i got my jdm d15b for $350 just the motor. nothing else. i think imma be using my vtec obd1 wiring harness.. will that work?</TD></TR></TABLE>
ok ok, i see... you can also sell that d15b for some good money toward i/h/e...
anyway... i dont know if this is the best way, but what we've done in the past is use the obdI harness on the obdII motor some things may be different, such as MAP and/or knock sensor?.. but we did that using a 99 b20 into 90 integra harness... this way, you are pure obdI...
dunno, this is what i've done...
Re: 2k ex motor into 93 eg??? (jdmsiR20)
kewl good lookin out....imma be gettin the motor any min now. my friend droppin it off. but i hear that the motor i have now has 5 more hp than the d16y8. is that true?? i just wanna use the tranny hahaha.. cuz im using cx and man its killin my power... i wanna also use the y8 manifold
em1gangsta
02-05-2013 11:25 PM
em1gangsta
Texas -OK -LA (Sales)
02-05-2013 09:02 PM
TeamVixiV
08-20-2002 06:12 AM
