2000 honda civic oil leak
Re: 2000 honda civic oil leak
I would guess it's coming from higher up. The rear main seal is lower than the area you're seeing - so I think you would see it on the inspection plate area as opposed to that high up the block. But, someone correct me if I'm wrong!
It's probably a leak from the distributor or VTEC solenoid, but the valve cover is another possibility.
Post more pictures from different angles, where you try to trace the leak source.
value cover done not long ago but ill check the distributior and the vtec solenoid thanks
