2000 civic manual transmission
Old 02-11-2016, 08:48 PM
ruralhdmrchanic's Avatar
Default 2000 civic manual transmission
Hey all
So i was givin a 2000 honda civic si but it needed the ISB done.
So i pulled it out and put a new bearing in
I pulled the transmission out the top
Removed clutch pressure plate and tstat housing.
I didnt have an alignment tool for the clutch so eyeballed it the tranny bolted up no problem so i think i had it lined up enough tigtened the pressure plate bolts through the starter holes
Put it all together
Now the problem
Started the car and put in gear release clutch doesnt move ot engage at all
Second and 3 when released it sounds like a little grinding but not bad but car doesnt even attempt to move
Whats everyones thought?
Clutch not lines yp proberly??
Oh also installed a new release bearing for the clutch
Old 02-11-2016, 09:19 PM
Former User's Avatar
Default Re: 2000 civic manual transmission
In gear, does the speedo register movement when the engine is running?
Old 02-11-2016, 09:21 PM
Yes it does
Old 02-11-2016, 09:23 PM
One of the axles is not fully inserted into the differential.
Old 02-11-2016, 09:24 PM
Ok ill check that out tomorrow
Old 02-12-2016, 11:15 AM
f15Civic's Avatar
Originally Posted by ruralhdmrchanic
Hey all
Put it all together
Now the problem
Where did you get the new input shaft bearing and how did you pay for it?
I need to change mine, I have been looking on line but the only thing I found was a bearing and seal kit..
Old 02-12-2016, 11:22 AM
RodWolf19's Avatar
Honda dealership
Majestic Honda online store
Old 02-15-2016, 06:42 PM
Ok sorry for the delay
So I got under the car tonight
Drivers axle is spinning looks like I may have a issue with the connection to the hub
But that's a different story i think
So pass axle isn't spinning
If I turn drivers axle by hand the passenger doesn't spin
But if I spin the passenger axle by hand the drivers axle does spin
Old 02-15-2016, 08:28 PM
Ok issue resolved
I noticed that the cc joint had become loose and and torn the boot
Since no play in the cv prior to this I will put the cv shaft in the bearings tested all is working
Will replace boot
just_hatched
11
12-18-2011 02:35 PM
SFBPI504
08-08-2008 09:37 AM
juevi (old)
08-21-2006 12:31 PM
Teg44
08-26-2002 05:13 PM
Quick Reply: 2000 civic manual transmission
