2000 Civic Ek Auto Transmission
before you read this please keep in mind I'm a girl and I'm only learning so don't call idiot
I have an auto EK civic and the gear changes are somewhat clunky in both drive modes (D3 and D4). The car sort of "kicks" into gear, especially into second and third most times shifting up. It also revs up slightly before going back into second whilst decelerating. I have no idea about the history of the car, I assume the trans has never been serviced.
Any tips? Does it really need a service or is it just a civic thing? The fluid is at the appropriate level, if slightly dark but not burnt in appearance.
Re: 2000 Civic Ek Auto Transmission
how many miles are on it? ...if the mileage is close to 150k and the fluid hasnt been flushed (which you dont know) i would recommend against getting it flushed now, however if you do have to add fluid for any reason use only Honda fluid, more generic fluids dont have the appropriate additives for our cars
Fish Twig
It could be the clutch 2nd/3rd gear clutch pack but yes do the drain and fill with oem honda fluid, drain/fill one weekend and then the next weekend do another and than do another weekend. You want to fully flush out all old fluid and by doing it this way you can get the fluid that is in the torque converter, its what build hydraulic pressure get that transmission moving. I'm keeping the answers simple so that you can understand.
I just dont see how the new fluids are viable compared to the older ones, when the transmissions have steadily gotten worse. I'm not about to try it to prove with an experiment, but most honda-enthusiasts IV spoken to have told me about bad experiences using the newer ATF in their older transmissions. To the point where they helped me find old fluid for sale. One guy has multiple bottles of fluid that's years and years old because he's tried putting newer Honda ATF in and the transmission didnt seem to like it.
Fish Twig
A complete drain of old fluid and than new fluid is necessary. If it wasn't done properly than he might have some mixed fluid still in the tranny. Also there is a certain time to check the fluid checking when cold is not the right way to check transmission fluid. I've used the new Honda transmission fluid and had no ill effects. I simply wanted to try out amsoil and see how it works. Still in progress but no ill effects yet.
I'm pushing 300K on the original auto trans in my 99 Civic Lx and did the switch to the new Honda ATF around 200K, still shifts great. Those that "encounter" issues switching from the old to the new fluid had an existing issue.
I have yet to see anybody provide concrete proof that the new fluid is not backwards compatible as stated by Honda. FYI, Honda will put the new fluid in if you have it serviced at the dealer, there is no choice to use the old fluid.
eg6_ftw
05-28-2013 07:31 AM
fatcatpaddy
04-20-2012 04:24 PM
sulmer
05-27-2008 07:54 PM
