1998 Honda Civic LX D16Y8 radiator issues
Old 05-28-2015, 02:57 PM
TokinKnight's Avatar
Icon3 1998 Honda Civic LX D16Y8 radiator issues
Okay so my 1998 Civic has been overheating for the last couple weeks. It overheats when I idle, goes down when I start driving and then sometimes overheats even when I'm driving. A few days ago the overheating issue skyrocketed and I ended up blowing a hose. Replaced it, filled it up again. Thought I bled the system properly, not sure if maybe there is still air in the system because it's STILL overheating. Doesn't overheat now when I turn the heat on. I know it's not the fan, because the rad fan turned on when I bled the system the other day while replacing the hose. It didn't overheat at all the day I replaced the hose or that night when I drove it for work. But starting overheating again yesterday when I was driving and is persisting still. Not sure what's going on or why it's still overheating. Help!
Old 05-28-2015, 03:19 PM
Another_Si_Guy's Avatar
Default Re: 1998 Honda Civic LX D16Y8 radiator issues
Check for a small crack in the radiator housing. I had a tiny crack on the radiator plastic on my EM1 and it was steaming and leaking coolant like crazy. And epoxy won't work. If you have a radiator crack, replace it. The new unit is only about $70 and it's easy to do yourself.
Old 05-28-2015, 03:22 PM
Pretty sure I ruled out any leaks, I will give it another look over though, thanks.
Old 05-29-2015, 02:38 AM
Turns out my buddy and I didn't wait for the system to cycle when we burped it, it was just low on fluid. Time to return that thermostat Thanks for the reply just the same.
Blake Horning
01-15-2018 01:14 PM
milkwasabadidea
01-08-2011 10:22 AM
halo2k7
17
07-23-2008 09:57 PM
Razr2
01-16-2008 04:59 PM
94civicsindy
10-02-2006 09:19 PM
Quick Reply: 1998 Honda Civic LX D16Y8 radiator issues
