1998 Civic EX shaking violently in first gear. Clutch?
My 1998 Civic EX shakes (or shivers) violently sometimes from stop to go in first gear (its a 5 speed). This only happens when the car has been running for a while (not while it has been sitting in the garage). It shakes when my foot is almost at the tip top of the clutch pedal and put I some gas.
Is this the clutch? All the other gears are fine. Is this dangerous for the car in the long run?
Re: (yoej8)
i kno exactly what ur talkin about cause me 96 ex is doin the same thing. it has nothin to do with the driver cause ive been driving a stick for more than five years now. it happens in first and in second a little bit sometimes. someone help us out. could it be engine mounts, tranny mounts, sensors, what?
Re: (ImaHondaLover)
how many miles you talkin bout on the clutch? could just be gettin old. mine used to do it, however i replaced the tranny and since i had it all apart and didn't want to take it apart again, i replaced the clutch as well so it could have been either one. if it's only in low gears though i think the tranny. but before replacing the tranny check the clutch since it's cheaper.
ok my car does this now too. i took it to my friend who works for honda and he looked at it. does your car make a whirly noise when getting pushed into first when it is moving? mine does. it turns out my syncros r out. at least thats what he told me. he checked my clutch and flushed my tranny fluid and it kind helped but not really. he said i just need a new tranny.
Re: (jonaldjenkins)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonaldjenkins »</TD></TR><TR><TD CLASS="quote">ok my car does this now too. i took it to my friend who works for honda and he looked at it. does your car make a whirly noise when getting pushed into first when it is moving? mine does. it turns out my syncros r out. at least thats what he told me. he checked my clutch and flushed my tranny fluid and it kind helped but not really. he said i just need a new tranny.</TD></TR></TABLE>
Sounds like a throwout bearing dude.
Re: 1998 Civic EX shaking violently in first gear. Clutch?
Driving a 1998 Civic LX with 125K on it. I am experiencing similar symptoms... violent front-end shaking in first and second gear. Sometimes it drives like usual, other times it will shake the whole car--all with the same clutch/gas release speeds and everything. To get around this, I push the clutch back in, and come back out with a lot more gas than normal. I kind of "power" through it.
I've also begun to notice that (again, sometimes) there's a brief scraping sound (like a glass cutter would make on glass) that happens right after the 1st or 2nd gear is fully engaged when I'm going up a steep hill.
Did anyone nail down what the shaking is, and perhaps it's related to this scraping sound? My only thought it the clutch. Thanks
civboy115
17
03-12-2004 09:26 PM
