1997 civic ex not start
Had my other engine spin a rod and so I just went and bougth another d16y8 and reswapped
and then when I got it all pieced swapped in and then I started itup it ran like a champ idles all nice then when I tried to drive it (my slave cylinder went out before the swap when the old motor was out someone pressed the clutch and popped the Slave cylinder busted) so when I tried to drive I Coudnt get in in reverse and then it stalled out I cranked it up agian it started and once agian I started then when i gave it gas the third time when it was running the Rpms acted up and the car stalled and then I couldn't start it due to the slave being all messed up so I bougth a new one next day put it on got the pedal feeling all good a firm and now it doensnt start I have no clue what is up with it any help guys will be great
More facts the other motor was a d15b block with d16y8 head and now I got a d16y8 and also when I try to crank it the speed gage bounces up and down if that helps
-vlad
-vlad
Re: 1997 civic ex not start
Please edit the text in your first post. It's difficult to read due to the lack of punctuation. It's like trying to read a long story without taking a breath.
No start basics
Answer all of these questions.
No start basics
- Does the starter crank the engine?
- Does the fuel pump prime?
- Is there bright white spark at all 4 plugs?
- Any CEL codes thrown?
No start basics
No start basics
How can I tell if the fuel pump primes
Yes white spark on all plugs
Yes CEL have to check, but the cel was on ever since the old motor and it was for the o2 sensors
And sorry I was writing his when I was trying to start the car was not paying attention what I was typing
But I jut don't get why won't it start up agian like it started up . But then it won't
Please now go back and edit your first post.
Turn key from off to ON(II). Do you hear the low humming noise of the fuel pump priming for 2 seconds?
When the CEL is always on, you don't know whether a new code is thrown. You won't encounter this problem if you fix all CEL codes, which is the smart thing to do anyway.
Also would know happen to know why the speedometer jumps around when I try to crank it up ?
Okay the fuel pump primes I'll check the fuse.
I get fuel and good fuel pressure.
I also get spark
And I get air
And when I try to crank it it feels like it's about to fire up. But then I doesn't but the headers get a little hot....... Dang this sucks lol first swap and it fails
I also get spark
And I get air
Yes the mechanic timing is good and the dizzy is timed to.
Like the first time it cranked up and ran fine warmed up and idles 750.
Then I stalled out due to bad Slave cylinder. I cranked it up 3 times the first day I dropped then engine In. Then my slave went out and I couldn't start the car. So I got a new slave cylinder installed it and bled the system and all. Tried to crank it and it does not want to start.
You are selectively answering some questions and not others and your answers are too terse:
Convince me of the firing order.
Post pictures of the cam and crank at TDC1.
Injectors spray fuel? Test whether the engine fires with starting fluid.
Compression test the cylinders.
Injectors spray fuel? Test whether the engines fires with starting fluid.
How can I test if the fuel injectors are spraying ?
I'll check the cylinder compression and post results.how would I start it work starting fluid. I'm kinda new to this whole scene but willing to learn any way posible. Let's just say bougth my civic when I was about to turn 18 still in school just got into this whole scene
Yes it fires up with the starter spray
And about the codes this is what I got
And the spark it's not like normal, it skips a few pulses
And the fuel injectors don't open to spray
You think it may be my ECU gone bad ??
okay checked they all work...... i have no clue going to switch out ECUs see if that helps.
but i have no idea why it doesn't want to fire up
Jack Murphy
06-27-2018 03:11 AM
CRXCRAZYD16Y8
02-08-2007 11:51 AM
pumpkyn
10
10-25-2006 01:54 PM
CRXCRAZYD16Y8
02-07-2006 04:09 PM
