Do pistons for a B18 in a B16 change compression ratios?
Old Aug 25, 2003 | 10:23 AM
SolidSpruce's Avatar
Default Do pistons for a B18 in a B16 change compression ratios?
i bought some new 9.8:1 JE's for a B18 off a friend, and put them in my B16. Do i still retain the 9.8:1 compression ratio? or did it drop?
I know the bore is the same on both motor, and the stroke is the difference......does anyone know of a compression ratio calculator online or something?
thanks
Old Aug 25, 2003 | 04:28 PM
TTWS6.
Guest
Posts: n/a
Default Re: Do pistons for a B18 in a B16 change compression ratios? (SolidSpruce)
yes 9.8:1 GSR pistons is 8:8:1 in a b16.. the deck height of the b16 is shorter, thats why
Old Aug 25, 2003 | 04:31 PM
hoya_10fintec's Avatar
a stock GSR pistons in a B16 = 8.?:1
but 9.8:1 GSR forged pistons in a B16 = maybe lower than 8.?:1...?
bump.. I wanna know too..
Old Aug 25, 2003 | 09:36 PM
Default Re: Do pistons for a B18 in a B16 change compression ratios? (hoya_10fintec)
if the deck is shorter....wouldnt that INCREASE compression, since now there would be less volume in the combustion chamber? i figured it might be something in the head, the depth of the dish....now im confused
Old Aug 26, 2003 | 03:16 PM
if I put a GSR head on a B16 block, it will raise the compression..
Old Aug 26, 2003 | 03:18 PM
SuperTeg95's Avatar
Yes a GSR head has a smaller combustion chamber. A b16 head will drop the cr.
Old Aug 26, 2003 | 03:19 PM
tegasaurus's Avatar
i believe its the stroke and rod height that changes the compression, but am not sure if it increases or decreases. I know a b18c to a b18a/b decreases about 6 pts.
there is a calculator on c-speedracing.com, check it out
Old Aug 26, 2003 | 03:29 PM
boosted92's Avatar
Default Re: Do pistons for a B18 in a B16 change compression ratios? (tegasaurus)
9.8:1 JE's will give you 8.8:1 in a stock bore B16, 9:1 with gsr head . Almost 8.9:1 in an 81.5MM B16, and 9.05:1 with GSR head .
Stock GSR's in a B16 will give you 9:1. Stock GSR's in a B16 with a GSR head will give you 9.15:1.
Old Aug 26, 2003 | 06:24 PM
Default Re: Do pistons for a B18 in a B16 change compression ratios? (boosted92)
I read that if you put GSR pistons in a B16, it will be lower CR less than 9:1..
somewhere around 8.5:1 or something... can't remember exactly..
someone confirm me on this?
Old Aug 26, 2003 | 06:39 PM
thid92's Avatar
can I haz?
i would be careful because the intake valves are bigger on a b16 than a b18b (which will cause major damage ) i hope ur talking about LS pistons if not dont worry.
Old Aug 26, 2003 | 06:50 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoya_10fintec &raquo;</TD></TR><TR><TD CLASS="quote">I read that if you put GSR pistons in a B16, it will be lower CR less than 9:1..
someone confirm me on this? </TD></TR></TABLE>
Nope.
81MM B16 w/B16 Head + GSR Pistons = 8.98:1 compression, so basically 9:1.
Old Aug 26, 2003 | 07:25 PM
ok, wow, that pretty wild, ok ok, so what if u put stock b16 pistons in a b18 block? with a gsr head? somewhere in the 11 cr maybe? if thats the case, for those people wanting to run all motor w/ higher cr stock b16 pistons would be a cheap way to increase compression!
Old Aug 26, 2003 | 07:58 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SolidSpruce &raquo;</TD></TR><TR><TD CLASS="quote">ok, wow, that pretty wild, ok ok, so what if u put stock b16 pistons in a b18 block? with a gsr head? somewhere in the 11 cr maybe? if thats the case, for those people wanting to run all motor w/ higher cr stock b16 pistons would be a cheap way to increase compression!</TD></TR></TABLE>
Yep, you could do that. Stock B16 pistons in a GSR would make 11.7:1 compression, and 11.4:1 with an ITR. Most people looking for something cheap would go with CTR pistons though, giving you 12.4:1 and 12:1 with a GSR and ITR, respectivly.
Old Aug 26, 2003 | 08:03 PM
damn!! that's pretty good than... maybe I should just throw in a set of GSR pistons. I'm only gonna be boosting up to 10psi w/hack..
Thanks
Old Aug 26, 2003 | 09:51 PM
11psiTurboSI's Avatar
I have JE 9.8:1 pistons for a gsr and in my b16a2 with stock headgasket its 8.8:1 and i hate it way too low
Old Aug 27, 2003 | 05:35 AM
Default Re: Do pistons for a B18 in a B16 change compression ratios? (9psiTurboSI)
yeah same here! i just realized this after having the motor built and running for 6 months now! what kind of power are u making? and how much boost are u running?
rudeboy
Apr 26, 2008 03:25 PM
BlueSi2k
Feb 24, 2003 10:32 PM
texasSI
Dec 9, 2002 11:12 PM
SIReg9
Nov 6, 2002 10:34 AM
blkDOHCsol
Sep 25, 2002 09:06 PM
