1995 eg civic coupe rattling
Old 02-17-2008, 08:02 PM
CiViCBruh's Avatar
Default 1995 eg civic coupe rattling
My car rattles alot beacause of my huge exhaust. Is there anyway to make the rattling go away? It is mostly in the doors and some in the dash.
Old 02-17-2008, 08:04 PM
DCSportEJ1Civic's Avatar
Default Re: 1995 eg civic coupe rattling (CiViCBruh)
if your doors are rattling from your exhaust its too loud
Old 02-17-2008, 08:05 PM
Thateguhate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViCBruh &raquo;</TD></TR><TR><TD CLASS="quote">My car rattles alot beacause of my huge exhaust. Is there anyway to make the rattling go away? It is mostly in the doors and some in the dash.</TD></TR></TABLE>
thats not your exhaust. Check your motor mounts... etc..
Old 02-21-2008, 08:09 AM
CiViCBruh's Avatar
the mounts are tight?
Old 02-21-2008, 09:11 AM
Remington's Avatar
Default Re: (CiViCBruh)
ok they're tight...... are they torn? solid mounts? first order of buisness if you have loud rattles is to track them down find out what's rattling 9/10 its a loose screw or bolt that takes an hour to find. Also consider (If you have subs) turning down the bass a bit see if that helps.
Old 02-21-2008, 09:13 AM
crazyguy's Avatar
make sure there is no damange or crack on the motor mounts and also check your exhaust rubber hangers,
Old 02-21-2008, 10:23 AM
[ivi]'s Avatar
Default Re: (crazyguy)
Probably his exhaust hitting the heat shield. I bet he still has it on stock.
Old 02-21-2008, 10:53 AM
ke98248's Avatar
Default Re: ([ivi])
Either that or its hitting the shift linkage -- or the chassis of the car.
ohemgiii
14
10-03-2015 03:52 AM
jkalex05
09-17-2012 05:09 AM
Charlie Moua
09-20-2011 02:53 PM
the171
03-30-2010 05:14 PM
blazinb16
05-23-2003 09:03 AM
Quick Reply: 1995 eg civic coupe rattling
