1994 Civic EX won't start...
Ok so I put my radio in and put it in place. Then sparks came from no where. From the radio area. (I knew the car has shitty wiring but this hadnt happened before...I just put the stock radio in...)
Then I tried turning on my car. First turn...makes the annoying sound when door is open. Second turn...nothing shows up on dash/cluster...so it won't even click over.
My lights works...annoying noise when door is open works...so I doubt it is the battery due to the fact that I was charging it the same day.
Just nothing lights up on my dash/cluster.
Anyone have any ideas what it might be and how to fix it?
Thanks in advance.
Thanks in advance.
Re: 1994 Civic EX won't start... (RaWrZie)
step one...check over you wiring... something is grounding out
step two... check for blown fuses and go from there
Re: 1994 Civic EX won't start... (badboyr66)
happened to me befor the blue wires that are from the back of the stero i took out then put back in and took the battary cables off for a few minutes and retryed to start the car and it worked
Re: 1994 Civic EX won't start... (kr0nic1)
Yeah I'll give it a try.
And the blue wires from the clip that goes into the stock radio?
Not even sure how to go about it.
BigDan28
04-01-2011 06:08 PM
coulsey
08-21-2009 02:40 PM
soulrider4ever
02-11-2004 03:42 PM
